1963 Impala SS, Revell
kaaliumkloriid
Postitus Postitas kaaliumkloriid » 24 Nov 2009, 16:54
Pane kaabule veel sarnast tooni roheline sulg :D
punase pidurisadula gäng
Postitus Postitas siim123 » 25 Mär 2010, 20:56
Tolle mudeli jupid on tugevalt jaolt värvitud. Nüüd ma jään Urethane lakki ootama, et kere ja osad jupid värvitud saaks, enne ei saa midagi edasi teha.
Hirmsat moodi meeldib kroomi/rohelise sobivus, päevavalges on väga ilus.
Postitus Postitas Black66 » 25 Mär 2010, 21:12
Postitus Postitas siim123 » 01 Apr 2010, 22:47
Midagi toimub...
Postitus Postitas siim123 » 02 Apr 2010, 00:34
Terve õhta olen siin jännanud ja tööd jätkub veel väga kauaks.
Postitus Postitas siim123 » 03 Apr 2010, 21:20
Pesco 280 hüdraulika kaadervärk, kahjuks pole nii pisikeste detailidega osav seega paras lopergune värk on. Aga olen üpris rahul. Nüüd vajab värvimist.
Postitus Postitas Black66 » 04 Apr 2010, 17:19
Normaljonks töö. Mitte et ma sellest süsteemist midagi jagaks. :D
Postitus Postitas siim123 » 04 Apr 2010, 17:42
Ega ta nii raske polegi kui keegi ilusti selgeks teeb. :D
Sain asjalikku abi layitlowi foorumist.
hey bro you could have just shot me a pm and i would have done anything i could to help you with them. first the pump itself consists of two parts. the pump and the electric motor. the entire set up for 1 pump consists of the 6 parts. 1. the pump and motor. 2. the tank. 3. the dump (sometimes 2 dumps). 4. the slow down valve. 5. the fluid filter. and sileniods (usually 2 for every dump). But i dont ever add sileniods to my pump set ups really. most people hide them like fuses.
the dump is basically a two way valve. it opens and closes to let the fluid go in two different ways. one way takes it back to the pump and then to the tank, and the other way sends the fluid to the cylinder. heres a few pics of the pesco pump set up, lables for each thing, and the fluid flow. i took pics with and without flash so i could make sure it shows everything good. the only thing not in these pics is the line going from the dump to the cylinder.
http://www.layitlow.net/pics/1003/pesco%20001.JPG
http://www.layitlow.net/pics/1003/pesco%20002.JPG
http://www.layitlow.net/pics/1003/pesco%20003.JPG
http://www.layitlow.net/pics/1003/pesco%20004.JPG
heres one of the names of the stuff it might help a little.
http://www.layitlow.net/pics/1003/3resi ... %20004.JPG
if you still need any help bro just ask me and i'll help in any way i can. ooo and as for the batteries. with these old school pumps one for each is good but the more the better. i would usually go wit at least 2 per pump. ;) :cool:
D. :biggrin:
Postitus Postitas siim123 » 29 Juun 2010, 13:42
Pagass näeb paras logudik alles välja, sai mitu korda kogemata ära lõhutud ja uuesti liimitud toda süsteemi, aga tööd on veel vaja teha ja eks kunagi hakkab ilus ka välja nägema.
Niisama lollitan, üpris head näevad välja isegi:
Siiski jään nende juurde 8) :
Postitus Postitas minimees » 29 Juun 2010, 14:20
Miks sa selle masina sisu ära ei flockinud? :D
Edit: pumba värvilahendus võiks olla roheline+ must. :wink:
Postitus Postitas siim123 » 29 Juun 2010, 15:05
minimees kirjutas:Miks sa selle masina sisu ära ei flockinud? :D
Pole flockingut, pagassi flockingu tegin üldse vatitupsudest :lol: , alles praegu tulin tolle peale. Laotasin liimi laiali ja surusin hunniku vatitupsusid peale, lasin kuivada ning seejärel ettevaatlikult kiskusin vähehaaval vähemaks kuni sai ühtlane.
Pumpade värvilahendus on seetõttu selline, et need on lennukipumbad. Pesco 280 ja Pesco 777 pumbad on väga väärtuslikud ning nn "Collectors items", neid kisuti teise maailmasõja aegsetest lennukitest välja, originaalvärv(ehk mustad pumbad ning kollased paagid) on see värv, mida paljud kogujad tahavad säilitada. Kohe kui midagi üle värvid või kroomid, kaotab see komplekt oma väärtusest hulga.
Postitus Postitas simmtann » 29 Juun 2010, 15:07
Poiss kurat, millal sa ühe stock impa teed sinna kõrvale? Pleku ja Bf Goodrich kirjadega vms.
Postitus Postitas siim123 » 29 Juun 2010, 15:14
simmtann kirjutas:Poiss kurat, millal sa ühe stock impa teed sinna kõrvale? Pleku ja Bf Goodrich kirjadega vms.
Bljät
http://www.plastikmudel.pri.ee/foorum/v ... sc&start=0
Postitus Postitas simmtann » 29 Juun 2010, 20:21
Plekut ei ole, Kirju rehvi peal ei ole ja liiga uus on ta ka. Igatepidi sitahäda noh! :roll:
